Oregon Celica
saathoff_ra24
Oregon Celica
hello my name is matthew, i recently picked up a 1976 celica coupe from a good friend of mine desperately screaming to be rescued. The car was sitting in a field for several years where it inherited a nasty ant problem. Since then i have torn the car halfway apart, solved the ant problem, fixed both front windows, and have began body work, I'm no stranger to old toyotas, i had an 81 starlet that i was building and planned on using for autocross. i work at les schwab and i look forward to learning many new things, meeting up with you guys and offering any help i may have
saathoff_ra24
Re: Oregon Celica
Welcome!
Ants! That's new. Usually it's mice.
Chuck
Chuck
"If you're going through hell, keep going." Winston Churchill
https://imgur.com/m2giFIx
Re: Oregon Celica
Welcome! What part of OR?
Come spring/summer we need to have a PNW meetup, I think there are a lot of us in OR/WA/ID.
1977 GT Liftback
3SGTE and stuff
3SGTE and stuff
Re: Oregon Celica
Welcome Matthew, this is a good group. We hardly ever hit each other!
skeptic...don't forget Chuck and Logan in Kalispell for that meet!
Cheers
Neil
Cheers
Neil
If it ain't broke, BREAK IT
Re: Oregon Celica
As in Montana? Uh, ok, sure. The more the merrier, but that might be a long drive. My distance limit is roughly 2 hours from Salem OR.
1977 GT Liftback
3SGTE and stuff
3SGTE and stuff
saathoff_ra24
Re: Oregon Celica
thank for the warm welcome. I'm actually in lebanon, that would be awesome to have a celica get together, are there a lot of oregon folks on here? very nice looking hatchback by the way!
saathoff_ra24
Re: Oregon Celica
UPDATE!!!
pulled the motor, sanded nearly the entire car to metal and primed the metal to prevent rusting.
used duplicolor build able/sand able high build primer.
tore out all the sound deadening with dry ice
bought myself a set of new weld on ae86 fortune auto coilers, there are about two weeks out, i called today, going to be using ra64 strut tubes and brakes
rota 15x9 -15 wrapped in 195 50 15 thunderer mach 3 inexpensive tire for daily use.
got a sparco sprint 5 seat because the stock drivers recliner was broke and it was either all the way up, or all the way back.
painting cleaning, collecting parts is what I'm up to. hope to have it running and looking decent by july!
Re: Oregon Celica
very cool ride... im glad you were able to bring it back from the dead!!
Foxy:My 1973 Celica-Powered By ITB'd F20c - SOLD 8/13
BUILD THREAD: http://1stgencelica.com/viewtopic.php?f=4&t=1221
Flyby Video's of Foxy: http://youtu.be/VSXNinaak8o
Re: Oregon Celica
Glad to see these cars getting properly restored.
Pics of the Starlet? Baby bro just picked up a Starlet.
1971, 72, 74 Celicas
1985 AE88 hatch
1989 240SX hatch
2020 86 TRD package (sold 2004 IS300 5MT)
1985 AE88 hatch
1989 240SX hatch
saathoff_ra24
Re: Oregon Celica
WELCOME! and thanks for saving that beauty! I've driven through Lebanon several times. We were recently in Newport last Oct. for Oyster Cloyster. Good times.
Just FYI. T3 sells hybrid knuckles to adapt the RA64 spindles to our RA24 control arms.
saathoff_ra24
Re: Oregon Celica
perfect!! actually one perk of working where i work is i can cross reference parts and found that the ra24 and ra64 share the EXACT same lower ball joint, i plan on actually using whole ra64 front crossmember/steering rack/rack and pinion my weld on ae86 coilovers from fortune auto are going here the 18th, I'm going to post a write up of how i made the suspension.
is it frowned upon I'm using my intro and turning it into basically my build
saathoff_ra24
