NEWBIE FROM SAN DIEGO
- Just on time
- Contact:
Hello gear heads,
I' m from San Diego ,Cali. Hey buddies, I am going to need alot of help. I am very excited about my project.
When i pay off the seller the total I owe. I will tow my 1973 ST /22RE Turbo celica to my work.
I will post pictures soon, when I find out how to. By the way can anyone explain how to post pictures? So I click on Img then what?
I'm Happy to be apart of this Community! Thanks,
Just on time
Just on time
- 75CelicaGT
- Contact:
Re: NEWBIE FROM SAN DIEGO
Welcome aboard!
Can't wait to see the pics.
If you have the pics on another site like Flicker, then you just pull them up and copy the link.
You then press the {Img} button above and paste the link there in between this: "[img]Paste%20Web%20Link%20Here[/img]" without the quotes of course.
was this the one on craigslist like a couple of months ago??
pics please. i wanna see the engine bay
add us on myspace... myspace.com/backindadayz408
Blogspot: Ithinkitsmiles.Blogspot.com
- Just on time
- Contact:
Thanks Pete,
Yes, this 1973 was on craigslist around Jan.2009 untill I closed the deal in Feb.2009.
Just on time
Just on time
also you can post pics thru PhotoBucket .... R click the img to copy and then paste it here in you post, very simple !!!
Now we want to see pics !!
Live LIFE the fulliest now... you don't know if you'll have tomorrow !!!
- 75CelicaGT
- Contact:
No Problem.
Would like to see more pics now! Plus a little bigger next time would be great
hey i live in sd too my car is not running atm but it will be soon
hey im also from san diego, whats going on with your car?
Member of IMG car club in San Diego, CA
Swap: 72 Celica w/ 96 Tacoma 2RZ Turbo (almost on the road!)
- Just on time
- Contact:
I'm back! I got my baby towed to my work.
Any chance I get, I work on her.
I don't know how the previous owner even got 50miles out of her.
The starter relay wires,were mixed up and one wire had a 20 fuse attached,that keeped on blowing.
Started her up,and she was misfireing and knocking,and I had the compression checked and all pistons are good!
I replaced the spark plugs,and now she runs better,but still knocking,so I got the valves adjusted,and replaced the valve cover gasket.
The gauges stop working took the dash apart. I turned the boost down,because I thought she was boosting 20psi,but the boost gauge was broken,but now it's fixed.
Then I put BG in the new oil,and BG in the gas tank to clean the injectors.
I made a bad mistake, I let the celica idle to clean the engine,and fuel system, and got caught up helping clients.
My baby overheated,and now she sounds even worse.
Tomorrow I'm off,so I will have more time to fix her up!
Last edited by Just on time on November 3rd, 2009, 3:56 pm, edited 1 time in total.
- Just on time
- Contact:
My 22RTE needs new bearings per.my buddy Vu. I will swap a 2jz-gte in my ra21. Do I have to customize the motor cross member,and the transmission mounts. I have found lots of 2jz-gte on the internet and they all seem to have auto transmission and ecu with un cut wires. If I buy it,can I use a 5speed w58 ,or the 6speed that is in the newer 2jz-gte with out buying a manuel ecu?
I will also put the hilux rear end,but I don't want to just cut and weild the ra21 brackets. I need to customized the rear end better,because I'm expecting to pop wheelies!
Thanks for your time and help.
"Young"
"Young"
Last edited by Just on time on October 29th, 2009, 9:26 am, edited 1 time in total.
- Blaze86Vic
- Contact:
Welcome to the forum.Just on time wrote: My 22RTE needs new pistons. I will swap a 2jz-gte in my ra21. Do I have to customize the motor cross member,and the transmission mounts. I have found lots of 2jz-gte on the internet and they all seem to have auto transmission and ecu with un cut wires. If I buy it,can I use a 5speed w58 ,or the 6speed that is in the newer 2jz-gte with out buying a manuel ecu?
"Young"
Why not fix the 22R? And now you can get good internals so that you can safely boost 15psi+ if you want. You will need to change out the rear end either way soon. And you won't be poppin' wheelies until you tub out the rear and put a ford 9" setup back there.
- Just on time
- Contact:
Thank you for your support. I changed my mind,because I not going to drag all the time. I'm going to rebuild my 22rte.
I'm working on the body now and after I add a roll cage. I want to swap the rearend with 1978 hilux. Is the ford rear end better some how? Then I will rebuild the engine.
good choice on rebuilding the motor
Welcome to first gen celics
nice car too.
oh and do u happen to have a picture of the turbo ? please.
and the ecm and ecm wiring......? im doing the 22RE EFI Swap into a RA21 too.
Thanks.
nice car too.
Thanks.
1)"GRANDMA "Always said "If you have nothing nice to say, Bite your lip-untill you do" oh and ! Old School RA21:From Stock to 7/8 scale 69 Z-28 Road racer,maybe?..
