As you check out my post let me know your opinion on should I fix the origanal 20r motor (headgasket maybe?) or I thought about going to a 7mgte?
RacerX wrote:like them ol skool Libre rims, got those on my 75. As far as 7m engine, it has good power but you will need to modify. Friend of mine did that on his 74 and had to get new rad since 7m is longer engine, he change his rear end since stock one did not hold up long, he also changed his suspension and newer brakes. The ol skool disc and drum was not good enough to stop it. Other than that it was a lot of work and he's a mechanic. If you have good mechanical/fabrication skills then it should not be too much of a problem but if you are not that familiar then it will cost a lot of money, trial and error. Now with that said, how do you know it's a head gasket problem on 20r?
this comment is universally the perfect response to anyones ordeal about their predicaments concerning engine swaps. a 7mgte is one of the holy grails of a 1stgencelica swap.slowmo wrote:Whether you build the 20r or not depends on if you have to smog the car, what you are using it for, what your budget is, and what you like.
