Solex Side Draft Carbs
Texas Red Toy
Post by Texas Red Toy »
Hi, I'm Toronto, Ontario, Canada I own 1975 Toyota Celica ST since Nov., 1981, I'm in process of rebuilding my car. I want to put a 18rg engine with Solex side
drafts. I came across the Solex Side Draft Carbs from 2T and I'm not sure if they would fit on a 18RG? Can someone help?
7t5-27
Re: Solex Side Draft Carbs
Post by 7t5-27 »
They will fit on the manifold, presume they are side drafts, might need to rejet but should bolt up. Good Luck Be Safe
Greg
It's a TA27 not a TE27
Texas Red Toy
thanks Greg, the side draft carbs are on the manifold
